axle distance
dirtyred
to anybody who has there busa close to them, can one of you in your spare time take a measurement from the center of the bolt where the swingarm attaches to the frame to the center of the rear axle? it would help alot! thanks in advance
Yorad
I can probably knock that out when I go home for lunch in an hour if it's not already done by then.
Tufbusa
Track Coach / TufPoodle Coach
Are you looking for stock setup measurement? Most have changed sprockets and that changes the length!
Is this for Gen I or Gen II?
Yorad
I have a gen 1 with stock swingarm and sprockets. I just measured at 22.5 inches almost exactly from center to center.
Hope that helps!
GMbusa
Even a caveman can do it.
Just set the proper chain slack and make sure the axle is even. Tighten the axle first, then snug up the adjuster bolts.
dirtyred
thanks a ton, i wasnt needing it to adjust my chain, i got that under control. ha ha Thanks a ton YORAD :beerchug:
Latest Bikes
Forum statistics
Threads
173,367
Members
47,925
Latest member
Pankaj
