AJ box with 2 dial progressive
BATTMAN
Does anyone know how to wire a 2 dial progressive with a AJ box? Do I have to take the AJ box off and run the progressive with the pc3R?
Commuta_Busa
AJ who... that things gotta be an oldie. Wasn't that one of the older btc boxes?
sorry but I can't help with the how-to on that one.
boosta1395
WHARE DO I FIND OUT ABOUT THIS AJ BOX? I PRESENTLY USE THE MPS INSTANT RICH AND IT WORKS VERY WELL
. JUST LIKE TO STUDY UP ON NEW STUFF
. THANKS
GIXERHP
A&J has gone out of business as far as i know, i dotn even know any one that has a manual for one any more!
chevelle
I ran a BTC box and a 2 dial in 05/06.
I can't remeber how i had it wired,so don't hold me to this.
Think you need to run 12v to the purple wire off box.
I have a BTC box for sale.
This box allows you to pick what gear you want to spray in (dip switch's)and at W.O.T. it opens the solinoid,kicks the injectors open.
BATTMAN
The A&J box is similar to the MPS box, except you can pick what gear you want the nitrous to kick in. I think I figured out how to wire it. I just wanted to be for sure. I dont want to find out its wired wrong the hard way.
chevelle
Easy enough to garage test,just twist the throttle and see if the solinoid(s)activate/pulse. That's what i did.
DirtyBird02
But with a box that open the injectors all the way,would hurt the performance I would think, meaning for exmp 40% to start with the spray,well no matter what the box is gonna open those injectors all the way being ton of fuel vs. little nos, u would defeate the purpose of spraying! IT woul be to much fuel.
