I am running a '99 busa motor in my sandrail. I have been using the stock external fuel pump and it is finally fried. I plan on installing an aftermarket Bosch or Pierburg fuel pump with an aeromotive regulator. My first question is in regards to wiring the fuel pump using the 12v wire from the ECM. Is this wire supplied with a constant 12v or does its voltage vary based on data the ECM acquires from its sensors?
I am also believe I need to set the regulator to 43psi before I hook the vacuum line up to it. Is this correct?
Thank You,
Derek
Thank You,
Derek
