Valingt
this is going in a 2003 busa.
ok so i got this pump and it fits but just barely. i have bench tested it to make sure it works all is good form the plug to the pump off of a batt.
the problem is im blowing the 10amp fuse when i plug it all in and use the bike.
so the question is what is wrong did i not hook the pump up right?
do i need to ground the take by bolting it down first?
does the pump pull to much for the bike?
does anyone know how much the pump needs for a fuse for it to work?
can i hook this up to a switch and just run it that way? also not the way i would like to go.
i have done the filter mod and it has a new filter.
