Buy a good service manual. It'll show you everything.
Here's a good way to adjust your chain. Put the bike in neutral and on the kickstand.
You'll be checking the slack using the bottom section of chain.
Find the middlepoint of the chain between the rear axle and the swingarm pivot.
Use a ruler or some type of measuring tape and hold it in place.
Suzuki calls for about 1.25inch slack.
(I usually set mine at 1inch, go for a ride around the block to seat the chain and then recheck the slack.
Alot of times when you adjust a chain it settles and loosens somewhat.)
I've heard several ways to check measurement and this is the way i like best. I divide the 1.25 measurment in half or close to it.
Push up on the chain lightly to remove the slack and measure the height, then let go and measure the height of the chain when it hangs free. The measurement should be half the desired slack. Then do the same pulling down. Both measurements should equal the chain slack of 1.25 to 1.50inch.
Or, if that confuses you. Here's an alternate way. Push up, measure, pull down, measure. The distance between the high point and the low point should be your desired chain slack.
The adjusting is easy. Loosen the adjusters, 12mm and 10mm. Loosen the axle --1 3/8" i think--
Sometimes a smack with your palm is needed to move the tire. Always adjust the chain side first, then match the adjustment on the other side. Recheck the chain after.
Once the slack is good, tighten the axle FIRST, then snug the adjuster bolt locknuts. No need to go overboard when tightening the adjustment locknuts.
Hope i didn't make it out to sound harder than it really is. Because this is about as basic of maintenence as you can get.
If you want a walk through or just need some advice, call me. I'll be happy to help.
540-223-3785 Paul
