If you download the service manual (use the search button) it will tell you everything you need to know. Basically the down and dirty is lossen the axle nut and adjust screw nuts, then turn the adjuster screw (evenly on both sides) out until your chain has half inch to 3/4 inch play in it with the rider. then tighten everything back up
