'99 VS newer Sub-frame strenght
buddha65281
Hey everyone, I just took a trip to North Cape, Norway from Germany on my '99 Busa and with the weight and everything the rear aluminum Sub-Frame (supports the seats and rear plastic) broke on my. I had it welded (alum) and then it did it again. I guess I just had to much weight for it. I just got another rear sub-frame from a 2006 and I swear it feels heavier. It also has metal welded to the vertical studs and my original did not have that.
My question: Are the new sub-frames STRONGER than the originals? I will weigh the old and the new (2006) to see if there is a weight difference, I am just wondering if Suzuki realized that the overseas market requires a heavier sub-frame.
Thanks for the replies...
Buddha65281
Germany and Ohio
PS... if you have never seen the MIDNIGHT sun, it is a beautiful sight...
the newer ones are not aluminum, thats why they are heavier. Not sure what year they changed probably 2001-2002?
They changed metals for the reason you speak of...breaking. The aluminum ones are good for racers looking to shave some weight.:beerchug:
seven pounds difference silver vs black subframes.
99-00 had lightweight silver aluminum subframes
01 to present are steel black colored.
