Hi,
Have a stock 99 Busa that is running very rich at idle. was fine in the morning but when i started it 3 hrs later it wouldn't idle and was running extremely rich.
No F1 codes or light and correct voltage being supplied to the boost sensor. Only way to get it to run is unplug the boost sensor then it is at least ride-able. changed the very sooty black plugs to a new set and no change, swapped out the boost sensor with a known working one and still no change.
Any help would be much appreciated.
Thanks
Thanks
