my low milage 2000 busa doesn't seem to be running right at speed. It seems like it's running out of fuel. I went to the local dealer and inquired about this, and I found out that suzuki had issued a bullitin about fuel pump issues back in 2000. the bullitin talks about clogging screens and kinked hoses. suzuki used finer mesh screens inside the fuel pump and petcock on the 99-00 busas. the bullitin said that to rectify the problems, a new petcock, fuel filter and strainer and 3 new o rings should be installed. the new parts had the larger mesh screens that were made standard after the bullitin came out. It's an exspensive little fix, as the parts alone are almost $200. Has anyone here on the board dealt with this issue? And if so, what did you do?, and did it make a difference? Thanks Tom
