Thanks for the info .. Your cowling help file was a life saver
Does Suzuki use std "green" prestone type antifreeze from the factory or is it a bike only thing?
I have lots of that around the house.
Also ... what was the sequences for lining up the push pins .. clips and so on on the plastics??
slip in front first then snap in top then push the rubber grommet pins in .. any help may save my plastics as they go back on .. thanks.
The factory coolant, from what I can tell, appears to be standard green stuff.... not bike specific. It is, however, kinda important that you use distilled, de-ionized water, if you are mixing up a batch.
Re: side cowling push-pins. Note there are FOUR (4) large rubber grommets to deal with, in addition to a ton of tabs/slots. Here is the correct order of install you want to use in order to minimize breaking crap off left and right:
1)FIRST do the very, very top-most (center) rubber grommet, closest to the fuel tank. This is the ONLY grommet that faces *upwards* (parallel to the ground)... the other three face *outwards* (perpendicular) to the ground).
2)Now wrestle with aligning up all tabs/hooks/slots toward the upper seam.
3)Then do the same for the nose area.
4)Then ensure the *forward*, upper grommet has its attending pin pushed in (this is located above and slightly to the right of the overflow reservoir).
5)Now for the fun part - the maze of slot/tabs/hose in the nose chin.... good times, there.
6)Finally, the lower two large rubber grommets.
