Seems like the 240 always has some problems. Mine is that whenever I ride anyone over 80lbs the weight rubs down on the tire. Can I tighten the spring? Any help is greatly appreciated. I have an 08.
My stock tire 04 is stretched 8". I have a stiffer spring. And it's adjusted all the way down. I am lowered about 2" front and rear. It will rub now and then on the right bump. Just something that's gona happen when you make those kind of changes. When you stretch it's just adding to the load the swing arm puts on the rear spring. Riding double adds more. The stretch is probably more the cause then the fat tire.
I have an 06 stretched with the 240 kit. Previous owner(im the 2nd) has it lowered with the dog bones, but also has Dapinci air ride on the rear. I weigh 220 and when it's at its lowest it doesn't rub
