Nice the tech seems to be moving slow but that mph is climbing fast. Not afraid to live in the red line l see.
It Is bad ass I looked at the dyno sheet and she’s not dropping off at all.That first pull started at 100 in 4th, I wanted to show the torque of the bike. I calibrated the Speedo so that should’ve been just about a real 200 on that run.
The engine hasn’t complained about rpm and I’m not that high up too often so I’m not worried.
There should be 4 vids total, idk how it posts since I’m on an iphone
You can’t complain about the rcc kit at all, it works perfect with the engine. I have been considering going to a different setup though.
what do you mean?
Currently I’m maxed out for power with the build since I’m on stock rods and I don’t have the budget for the ultra plenum and all supporting mods.
I’ve been thinking about going to a ball bearing turbo or maybe a twin scroll setup.
That's what I'm talking about
What kinda boost levels are you talking about? And safe numbers for WOT?You don’t “need” an ultra plenum to make more HP. You can do rods, and turn up the boost along with the meth kit.
I want that done to mine!!!You don’t “need” an ultra plenum to make more HP. You can do rods, and turn up the boost along with the meth kit.
I think we were at 380hp on pump fuel on this one.
Question: I saw a power commander in the trunk... it wasn’t tuned through the ecu?
