2012 Battery - What is Best?
Powerhouse sells a range of batteries , from Shorai lithium like I run on my standard street motor , to a really powerful type ( forgotten brand ) that is perfect for cranking big HP turbo motors . Worth giving Frank a ring , I bet he would have it too your door fast as !!
the 720CCA battery is a Full Spectrum POWER PULSE IPT10(S)…. powerhouse sells them... This is the best battery you can buy.... perfectly suitable for a stock motorcycle..... Not only is this battery 720CCA(yes you read that correctly)… it is also 12aH.... meaning MORE capacity than stock battery(or any battery that I have seen for hayabusa)….. frank at shop Phone: (631) 491-6767
What is the state of your bike?
Stock? Turbo? Big bore kit? High Compression?
If the bike is as it left the factory, just grab a standard oem replacement. Generally last 3+ years
Thanks for the comment. I didn't think of this.
Bike is stock.
I installed motobatt, made in California.
No problems until now.
Did it die?
I bought the bike used, after 3 months the battery died. So I put a Chinese called Moura here in Brazil. Good for cars, bad for motorcycles. After 9 months the Moura died too. So I put this motobatt, my mechanic said this is better than yuasa nowadays. I already have it for 3 months, pretty good until now. Let's wait for the future.
