2008 Suzuki Hayabusa no dash lights or brake light
Start with the fuses and then to ground wires. if not that look for pinched wires and check your brake light switches, this assuming bike starts and runs.
This pic from a Gen 2 manual
#18 is the fuse box
underneath L side top body panel which you can remove without having to pull any of the other panels off
Note steering damper to orient
