I have a 2008 hayabusa that i am still trying to get the bugs worked out of. The thing that is driving me nuts is a buzzing noise at 3500 rpm that I believe is coming from the stator. It makes the noise after its warm. When i bought it had a clear cover installed and when i revved it in neutral it looked like a oil stream hitting the cover causing the noise. I then replaced the cover with an aluminum one i put the stator back in the same way i took it out. Any help would be great cause it is driving me nuts Thanks Eric
