lowered97a4
So ive been having problems a day after i cleaned some rust out of my tank, I notice more in second gear and up if im cruising along in 3rd gear roll on the throttle its fine to about 60 percent throttle then it just doesnt really accelerate after that sounds choked down same goes for all the other gears. So i decided to take the fuel pump assembly out tons of rust in the bowl and the sock cleaned it all out im still getting the same symptoms. Next thing i tried doing was putting a new bosch pump in that i found from one of the threads still the same, ive cleaned all the mirco filters in the injectors checked connections. I have a bazzaz on my bike i disconnected all that still no difference. Im almost thinking my pump is **** but it almost feels like the secondaries are not spraying maybe not enough fuel pressure. I dont have a stock cluster on the bike cant check codes some help in the right direction would be very helpful right now im stumped.
[/IMG]
