You’ll only blow fuses if you’ve been chopping and changing your factory wiring harness, or if add a device that draws excessive current thru the circuit you’ve tapped into.
Otherwise, you have a spare fuse(s) in the fuse box on the bike, already.
Have you changed the harness in any way?
