homernukem
I bought this bike a while ago and have only test drove it.
It has a very hard time starting. The only way to start it is with a battery charger hooked up and crank it for an obnoxious amount of time while giving it throttle. (Side note, it won't even try to start with the power commander unhooked).
Once it starts it runs fine.
It has a new battery, new iridium plugs, and I cleaned out the fuel pump, fuel lines, and injectors.
With a plug out I can watch the spark and it sparks two or three times in a row then misses one or two times in a row. I don't get any FI codes.
I thought it may be the cam position sensor, the sensor ohms out at 1,173 ohms. The pin on the cam sticks out .3060 inches. I tried to pull on it with vise grips to get more of the pin to stick out but it wouldn't move.
Does anyone have an idea what may be the matter?
