Busa Sam
Hello
So about the bike...
It's a 2002 limited edition with 295 miles, yes 295.
Long story shory, it has sat for 13 years without being cranked or anything.
The clutch plates are being pushed out, but they are not separating so when I'm pulling the clutch lever in and kick it in 1st gear...it lunges and stalls.
I have installed a new clutch kit...rebuilt the slave cylinder...measured the plates fibers and whole stack 3 times...purchased a mityvac to make sure all the air was out of the line and I just can't figure it out.
The plates are not stuck together, I just removed them 2 days ago multiple times to check everything...the basket is not notched, it's basically still new.
I do have the flat washer and wave washer installed correctly, haven't tried removing them to see if it works though.
Any ideas would be greatly appreciated.
Yes the kickstand was up when I first tried....and on the rear stand it will just start turning the rear tire when I put it in 1st gear with clutch lever pulled.
It just doesn't seem to be pushing the plates far enough to separate them, even though they seem to be pushed out a good amount.
Thanks
Thanks
