Kiwi Rider
I was getting a bit tired of sitting in front of the computer, watching you tube vids and docos, and I've been avoiding going out and spending money, plus it's winter here so . . . . . the other day at work a bloke I've never met drops into work and asks for me.
Turned out he worked with my old workmate ( an excellent Subaru and Toyota technician), and my buddy had given him my number as a possible lead to fix his new (to him) bike he had just bought.
It's a little 1990 Bandit 250 which he got to commute on, and on the ride home from picking it up, it broke down.
So anyway . . he's a really nice guy, 65 and just retiring from full time mechanic duties, but not confident on working on bikes, just rides a bit.
I picked it up on my trailer and brought it back to my cave and started assessing the problems it has.
The rear axle was loose as a goose, the front brake was spongy with air, the fork seals leaking like a siv, the rear brake hose banjo bolts loose, and that was just the safety check items!
I moved on to the poor running issue, removed the plugs, removed the airfilter and airbox, removed the carbs and took a few pics of what I found . . . .
Here's the bike . .
air filter . .
This is how I found the throttle tube . . . somebody's had a play . .
Carbs . . .
I had little Jimi helping and even he was shocked at the poor condition of the bike!!
Next step is a compression test, if it's OK on compression I'll go ahead and sort the carbs out, if comps are low, I'll do a leak down test to see whether it has tight valve clearances or worn rings.
Will keep you informed. Kiwi
Here's the bike . .
air filter . .
Carbs . . .
