TreyYoung
OK Team, I am at 15k miles. I have read the recommended service and see things like changing the plugs (also said change plugs @ 7k which i did not do), checking valve clearance, etc. Just looking for some guidance.
What would be the best plugs to use if needed (I have car plugs that I have not changed in 100k miles) ?
How much should I expect to pay a mechanic for checking valves & changing plugs? and is this usually packaged with oil & filter change?
Anything I should be looking for when I have this done??
Yes, I know these questions have already been asked at some point, and located somewhere in our notes; but I am to lazy, or too efficient (depending on how you look at it) to go look.
By the way, had the chance to run with a friend on his 2012 ZX-10. Both of us are about the same build and weight 230lbs suited. The ZX-10 is awesome but it did not pull on the Busa. I will be taking the Go-Pro with us this weekend. Few pics below:
