(2005 hayabusa)Took my bike apart for some overdo mainamce and paiting. Then messing around bought a used PCV the powe or status lights neither comes on even when the ignition in the on position. It does however turn power on green when hooked to the laptop. I did notice red flashes from the status light momentarily. I also had my ecu reflashed a while back before I even decided to go with the PCV. Now putting everything back together the bike does not turn over at all toock the starter case off to see if there was any movement at all, nothing. I did also try disconnecting the PCV but still the same. The battery is brand new. Lights come up and pump comes up and the fuses seem to be good.
Current mods are full Ti-force exhaust, air box mod with k&n air filter, pair valve removed, charcoal canister removed, clutch mod and springs
