angel racerx
When its cold, the starter spins and fires right up. Ride it for 20 minutes cut it off and try again. It turns slow headlights dimming and almost go dark, and stops after 3-4 rotations. brought new battery .
Fired up fine 4 times in a row while it was cold, rode it 20 minutes, and then the same issue. It turns over slow 2-5 rotations and stops, Headlights dim.
If i hit the starter button and it turns over slow, i release it, wait for fuel pump to stop running and hit it again sometimes, very randomly it will spin fast like everything is ok and the bike starts. Cut it off ,hit the starter and its dead again.
The colder the bike is the more consistent it starts the headlights shining strong while cranking. The hotter it is, the starter more consistantly doesnt work, with headlights dimming and each time it sounds like the fuel pump gets weaker. That one time you hit it just right the fuel pump sounds strong the starter is strong and the headlights are bright.
