07 busa reving high when turning right help please
busarider2015
when I turn busa to the right the bike does really high rev help please! I did remove all the controls and installed new ones! which throttle cable do I adjust coming out of control right or left?
I think the fast idle (choke) cable is the problem...
no
@busarider2015
if the grip has no "gap" of ~2-4 mm (0.08 - 0.16 in) , the (throttle´s) "puller" cable is too tight.
loosen it a little bit and all your issues should be history.
look at the manual ("Throttle Cable Play Inspection and Adjustment") at page 0B-12 at gen2 & chapter 2 at ´99´s manual
