Ok, I am putting the Rostra on the bike and could use a bit of help here. The VSS wire for one and do you know the PPM of the unit? (guessing 80K and will need the signal modified)
And I KNOW this has been posted a few times but want to verify it for the tach wire:
<div class="iF-Passage"><div class="QUOTEHEAD">Quote:[/Quote]<div class="QUOTE clearfix"><span class="quoteBegin"> </span>
go to the ecm , its the green wire on the left plug[/quote]
Thanks and I will document and photograph the install
