View Poll Results: How should I adjust my forks?
Voters
15. You may not vote on this poll
  • Increase rebound AND compression damping
    11 73.33%
  • increase rebound BUT decrease compression damping
    3 20.00%
  • use a lighter fork oil
    0 0%
  • use a heavier fork oil
    1 6.67%
  • decrease the preload (if possible)
    0 0%
  • do nothing and suck it up
    0 0%
Results 1 to 14 of 14
  1. #1
    Rookie BanditKing's Avatar
    Join Date
    Aug 2005
    Location
    Toronto, Ontario (Canada, eh!)
    Posts
    251
    Default Need Suspension Adjustment Advice
    Okay, so after riding Deals Gap for the first time, I took the plunge and decided to firm the suspension up on the Busa.
    According to RaceTech, for my weight, I went with 0.95kg/mm springs up front and a 14 kg/mm spring in the rear. I was willing to sacrifice the plush ride the Busa offered for better/faster handling.
    On smooth pavement, the bike is now WAY more responsive and nimble.
    I did notice however that over pavement that "undulates" (like gentle waves, not like ridges or bumps), there is a tendency for the forks to compress on the way up and then spring me up as I approach the crest and go over it (feels like bouncing on a pogo stick). This has caused the bike to become unsettled at speed particularly when one pavement "wave" comes after another in quick succession (like on the Gardiner), and especially if the bike is leaned over. (it feels like i'm smacking into the next wave)
    I've been meaning to adjust the fork settings (more rebound and compression damping) but haven't gotten around to it yet.
    Yesterday though, on a ride through some twistie back roads I noticed that over some of the rougher stuff (patched/cracked pavement, tire ruts) in some of the corners the bike really became unsettled to the point were i thought i'd lose the front end it was bouncing so much. A friend behind me even commented that he could see that I was getting bounced around. It completely made me lose confidence in the corners.
    So if I set the damping higher will the handling be worse on the rough stuff?
    What possible options do I have?
    Heavier oil?
    Less preload (I don't know if this is possible yet)?
    Increase rebound damping, decrease compression damping?
    Increase both rebound and compression damping (I get the feeling this won't help on rougher roads)
    '05 Silver & Blue Hayabusa
  2. #2
    BusaStampede Rally Master
    Scar's Avatar
    Join Date
    Jun 2007
    Location
    San Diego // Phoenix
    Posts
    14,404
    Default Re: Need Suspension Adjustment Advice
    Quote Originally Posted by BanditKing View Post
    OK: I'm not an expert on this stuff, so I took mine to a shop which has a race team and let the expert do it.
    It cost me $30.
    That's all I can offer you, Bandit. It was the best $30 I have thus far spent on that bike. The difference is so incredibly amazing.
    Additionally, it took them less than 45 minutes start to finish, which seems like a paultry amount of time for changes so significant.
    It's my soundest recommendation.
    I know a lot of people like to work on their own equipment...and I support this wholely...but if you pick the expert's brains while they're doing their $30, then you'll know what to do in the future.
    Good luck, bro.
    PS: I didn't vote in the poll, cuz there wasn't an option which best described my advice.
  3. #3
    Hayabusa Legend ToXSicK RoCKeT's Avatar
    Join Date
    Jul 2008
    Location
    Modesto, Ca
    Posts
    2,086
    Quote Originally Posted by Scar View Post
    It cost me $30.
    Good luck, bro.
    I whould have to concur with Scar on this one, i for one am one of those Guy's that LOVE to wrench on my own bike, But i have not a clue when it comes to dailling in suspension And i know that's one aspect on a bike you dont just start "turning screws on". I whould definitely seek professional assistance at the very least!
  4. #4
    On a Steel Horse I ride.
    BusaWizard's Avatar
    Join Date
    Dec 2005
    Location
    Kansas City, Mo.
    Posts
    11,451
    I concur.
    If you're not living close to the edge, then you're taking up too much space.
    Fast is easy. Quick is hard.
  5. #5
    Hayabusa Immortal
    Commuta_Busa's Avatar
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,670
    do one change at a time... is your sag setup right?
    add some rebound and see what happens. Add three clicks so you can really feel a small change. Adjusting the compression/rebound by only a click will be very hard to feel a difference.
    Call the folks at Race Tech for some help too. Explain the situation and ask them how you should make changes to improve the suspension step by step.
    2009 Super Streetbike's Top Speed Challenge Winner
    Unlimited naturally aspirated class
  6. #6
    Trouble Makers Inc.
    Mr Bogus's Avatar
    Join Date
    Dec 2006
    Posts
    2,085
    Did you get the valves too? I had the springs and valves installed and like you found a world of difference initially.. the problem you are describing (the pogo stick) will go away if you set the rebound up a click or two..
    I pushed mine to extremes on either side of the adjustment and it was pretty interesting.. I found a 1 mile section of road (pretty rough) and rode over it in both directions a number of times while dialing compression and rebound all the way up and down..
    The ride went from a covered wagon to a Cadillac I then went from the ultra soft to just "firm" Was really time consuming but pretty worthwhile learning experience..
    The compression seemed to have the most effect on comfort (getting jarred from initial bump) and working the rebound I found that it did not make a lot of difference unless there were a series of bumps in a row, too soft the bike rocked like a horse, too stiff and the front would start to load up and get too stiff..
    You will save a ton of time and work if you find someone that can do the initial setup but you still have to fine tune it for your own liking.. just time and patience.. (but worth it )
    It would be really worthwhile to note what click settings you find for cruiser soft to "sport firm" and then tweak them as needed (commuting to riding area then home again)
  7. #7
    Top Gun mike04busa's Avatar
    Join Date
    Jan 2007
    Location
    Middletown Connecticut.
    Posts
    1,152
    With stiffer spring's it may act like you sped-up the rebound(loosened it). Try tightening the rebound 1 click at a time.Ride it for a few day's and try 1 more click.Put some seat time between change's.
    Other Toy's
    71 Big Block Chevelle
    04 KTM 200 SX
    05 KTM 125 SX
  8. #8
    GPW
    GPW is offline
    Hayabusa Immortal
    Join Date
    Jun 2006
    Posts
    6,551
    First decide how much better you want your chassis, better than stock or racing quality. Properly set your sag first, the other stuff is pretty easy. We do suspension tuning all the time, many members here have used our services. We send you out on three rides over an hour and tune three times or until its to your liking. $100.00 per hour.
  9. #9
    Hayabusa Immortal
    Join Date
    Mar 2003
    Location
    Carteret, NJ
    Posts
    7,670
    This is very good advice. An expert suspension guy can get you setup in the right ballpark with the inital settings. After a short ride and your feedback they'll really dial things in for you. I've seen alot of places that do this for 30 or so bucks. They're filled with knowledge and are very open to your questions. They wont techno-babble either.
    It cost me $30.
  10. #10
    Professional Pilot
    Join Date
    Mar 2008
    Posts
    809
    Search the threads, and you shall find the most comprehensive and informative write up on suspension tuning. When I changed the front spring, I went with this information, and tuned it half assly. It still made a totally different bike far as suspension performance goes.
    However, hiring professional service is a good thing. My problem was that once I learned how sytraight forward this is, I felt confident enough to try it by myself.
    Maybe you can save youself some money and donate the fund to org? At the end, you are the better master of your machine.
    Good luck.
    Posted via Mobile Device
  11. #11
    Track Coach / TufPoodle Coach
    Tufbusa's Avatar
    Join Date
    Sep 2004
    Location
    The Evergreen State
    Posts
    7,372
    You can calm the pogo stick syndrome with rebound damping. The stock busa valving is notorious for being weak on rebound. Adding stiffer springs compounds this lack of rebound.
    You will be much better off to have a suspension guy set up your baseline. You can then make small adjustments to your liking!
    Suspension is an art all it's own. Not just anybody with a screwdriver can do the trick. However, if you don't play with the adjustments you'll never learn.
    Riding well is not only a great way to get around a racetrack at record pace, but also a terrific way to become an old rider.
    Both are excellent goals!
  12. #12
    Hayabusa Immortal
    Join Date
    May 2005
    Location
    St. Louis, Missouri
    Posts
    13,006
    IBA #39091
  13. #13
    Join Date
    Aug 2005
    Location
    Posts
    251
    okay, so I've played around with my suspension settings and this is where I'm at:
    my weight with gear 215 lbs
    front springs: Racetech 0.95 kg/mm spring upgrade
    rear shock spring: Racetech 14 kg/mm srping upgrade
    valves: stock front and rear
    front preload: back out all the way (8 lines)
    front compression damping: turned OUT all the way (minimum damping)
    front rebound damping: turned OUT one click (maximum damping)
    rear compression damping: turned out fifteen clicks
    rear rebound damping: turned OUT eight clicks
    these numbers seem to be working for me, with fairly good pavement that undulates a bit, and has the occassional asphalt repair job. Cornering seems pretty good, and I've got my confidence back.
    It seems that the shop that did my install had not only stiffed the springs but the maxed out compression damping on top of that, making my suspension WAY too stiff. The pogo-like feeling over bumps was the springiness of the tires as they compressed instead of the forks and shock.
    do others have similar settings?
    I still think that I might have a bit too much rebound damping up front, but I've been told that I have to have at least one click out from full closed or else the circuit will be closed. Is this true? Should I go for Racetech's gold valves as well?
  14. #14
    Professional Pilot
    Join Date
    Mar 2008
    Posts
    809
    Mine has much stiffer preload front set up, and I'm only 170lb.
Similar Threads
  1. rear suspension adjustment question
    By Max Speed in forum General Bike Related Topics
    Last Post: 03-24-2009, 05:53 PM
  2. Suspension adjustment
    By coyote69 in forum Engine and Performance mods
    Last Post: 09-01-2007, 07:42 PM
  3. Suspension Adjustment !
    By Bosshound in forum General Bike Related Topics
    Last Post: 08-01-2007, 07:08 AM
  4. SUSPENSION ADJUSTMENT QUESTION
    By OB_skid in forum General Discussion
    Last Post: 08-15-2000, 02:14 PM
  5. Front Suspension Pre Load Adjustment
    By OB_RCOREA in forum General Discussion
    Last Post: 03-12-2000, 12:39 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
