I have used the search function but have not found the answer yet. I really dislike the knocking sensation when revving the motor up to 3 or 4 k and pulling the clutch in. I was told it was in the clutch basket so we pulled the clutch apart and the springs are loose in side the basket. In other words the springs slide left and right in the basket. I was told it was probably from abuse and a new set would fix the problem. While I am in there I am going to add a billet clutch basket. Is that loose spring normal or is that from wear? Am I missing the big "Clutch thread" somewhere, because I cant believe this isnt discussed more? Yes, Im a newbie. |
| Thank you for answering my question, I did see a thread about that in the search function.
| Yes, that is what I have now. I dont see the wear.....its the fact the spring does not spread out enough to fill the pocket they sit in.
I know there is one that does fit the pocket, maybe 2 or three. The springs also have different wire diameters. I believe these two things were done to make the cushion effect progressive.
______________________________________
03 AE 2006 PMRA Street E/T Champion 2007 PMRA Street E/T Champion Pipe and stock arm Fat Old man 9.90 @ 139.16 Room for improvement! A bit longer and a bit of motor work 9.36 @ 147.39 |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| clutch spring bolts? | XZZR1200 | General Bike Related Topics | 4 | 03-14-2009 07:56 PM |
| Clutch Spring Question... | SHADiGUY1 | General Bike Related Topics | 17 | 08-07-2008 11:45 AM |
| Rear suspension spring pre-load question | USN05LE | General Bike Related Topics | 1 | 07-20-2006 08:58 PM |
| clutch spring and washer placement...... | BusaReds | Maintenance and Do-It-Yourself | 0 | 05-19-2005 06:57 PM |
| stock clutch spring free height? | tricktom1 | General Bike Related Topics | 1 | 04-03-2005 09:33 PM |
