Road Weazel
OK, the n00b has another set of questions. My bike is is a '99 and is set up with a Hahn Racecraft turbo set up, water injection and a variable pressure fuel regulator (40 PSI to 80+ on boost). I'm going to upgrade to the '05 ECU and rotor and get away from the 16 bit processor and PC-II. I'm building an ECU Interface Unit so I can hack the ECU but I'm only planning to remove the top speed limiter and change the timing (retard after 5K RPM and possibly advance below that). I want to use a Dynojet PC-V and Wideband with Autotune for the fueling. Autotune sounds like a good idea to me because I live at an altitude of 5,000' but work in the valley around 1,000'. I will have this dialed in on a dyno, with an A/F meter...
So, now that I've laid out the plan, DJ has a newer PC-V set up with a Pressure Input that can adjust the mapping based on the level of boost. Do I need that if I have the variable rate fuel pressure regulator that adjusts fuel pressure based off of boost? It seems somewhat redundant.
Thanx, guys. I'd appreciate your input.
Weazel
Weazel
