Turn signals set up as running lights
well i went the old route and used blackbird mirrors which are going to be next to impossible to find. but if you do then you have scored big time.
OK...what's the difference between the 30SMT and the 48 SMT?
In a side by side comparison, i really don't see a difference to tell you the truth.
Some people just seem to want more!
As you found out GixxerHP is the one who does this! Neat mod... Did it myself! makes you stand out more!
Here is what I run....
https://www.kisantech.com/index.php?cat_id=4
It has automatic turn signal turner offers.... your tail and front turn signals run as running lights at 50% all the time and when you hit the brakes all your running lights now flash to get more attention...
Pretty cheap and super easy to install. I think it took about 45 minutes to get it done...
It also has some flasher modes like side to side, front to back and multiple flashes that you can use to increase attention if your stopped on the side of the road or there is a need to escort someone...
CAp
first pic is running lights, second i hit the hazard flashers. that's gixerhp's mod.
looks so sick bro.
