Transmission Snatch
Discussion in 'Gen II Busa Information' started by gixerich, Jul 20, 2016.
  1. gixerich
    gixerich Registered
    Contests won:
    hello there from Manchester, UK! I have a 2015 model and it has an annoying "snatch"/"clunk" when releasing the clutch to set off. it is only really once bike warmed up on a ride. the chain tension is ok and my garage can't see any problem. Is this normal? it's just rather irritating. thanks, Rich
  2. Sputter
    Sputter Registered
    Contests won:
    Name:
    Howard
    Sir, what is your throttle position when this occurs?
  3. gixerich
    gixerich Registered
    Contests won:
    Sputter it's whatever throttle position, either setting off steady or higher revs. Not as bad if roll backwards slightly before launch. It is like it's taking up slack in the chain but like I say chain tension is fine
  4. dave s
    dave s Registered
    Contests won:
    Name:
    dave
    Sounds likes your cush drive,grab the rear sprocket and check movement, what's the mileage
  5. Sputter
    Sputter Registered
    Contests won:
    Name:
    Howard
    So I take it only on launch? It is possible the dampers in the rear wheel are loose. The replacement dampers are a good inexpensive upgrade regardless. The other item may be the clutch. You can check Brock's or MTC for the upgrades but check dampers or upgrade first.
  6. dave s
    dave s Registered
    Contests won:
    Name:
    dave
    I had a knock / clunk when pressing rear brake ,ended up changing chain and sprockets but still there. In the end removed both side failings and tried to get a better idear, found bottom engine mount slightly loose Even though it looked tight so retorqued all mounts and solved.Try the easy things first, remove back wheel and check cush drive rubbers for wear cracking before getting your money out.It cost me £220 to find that out
  7. GoldenChild
    GoldenChild DID HE REALLY SAY THAT? Donating Member Registered
    Contests won:
    Name:
    Daniel London
    it is this piece loading and unloading.. convert to 1 piece and done.. we have in stock lmk
  8. gixerich
    gixerich Registered
    Contests won:
    Dave S the mileage is only 8000 miles, had bike 18 months from new, cush rubbers 'seem' fine. Golden child what is the name of that part, where can I get it and how much is it?
  9. plucka
    plucka Registered
    Contests won:
    Name:
    Lance
    I have that noise to when hot. I also can hear it changing down from third to second to 1st. 2013 with 4000 miles. Did you find anything else about it?
Share This Page
