Well if you've ran 200 with 18/41 I will try that first since I really despise pulling off the fairings to run a single pass or 2 to just get 200...I don't care to run the absolute max speed possible...just want to break 200mph. I've been told you can run 200 with 18/41 but the concern was enough adjustment in the stock chain to allow it to fit. I believe 200 is just about it for that gearing with the stock cams though.... I also read your write up...190hp stock is almost too good to be true...that's a rare bike my friend. I have pipe and ECU flashed with 20/50 amsoil with Ryan Schnitz tunning and both my 08 Busa and 09 Busa pulled 184hp at the wheel at 107 tq I still run the stock filter but that's only good for 1-2 for a Piper or Bmc race. I mfg those ram air kits back in 2000 for my old busa and sold a few hundred to members back then LOl. I've not done it to the 09 yet...just curious to break the 200 and I have about 12 mile stretch to
I think I'd go with a lighter amsoil, shear strength is close but easier to pump freeing up some HP, remove seat for some can help your tuck and for a cheap defeat of the limiter use a speedohealer it will also correct your way off speedometer when your done. Mine is as close to a gps as you can get at 60 and 90, for regular riding that is good for me.
