SuperSprox Chain & Sprocket Kit for Suzuki Hayabusa
Discussion in 'PashnitBusa.com' started by pashnit, Sep 11, 2013.
  1. pashnit
    pashnit Site Sponsor Registered
    Contests won:
    Name:
    Tim
  2. pashnit
    Contests won:
    Name:
    Tim
  3. pashnit
    Contests won:
    Name:
    Tim
  4. E Zurcher
    E Zurcher Registered
    Contests won:
    Re: SuperSprox Chain & Sprocket Kit for 08-13 Suzuki Hayabusa
    Mine's installed already:laugh:
  5. _WOLFMAN_
    _WOLFMAN_ Canuck Ground Pilot Donating Member Registered
    Contests won:
    Name:
    Dean Parsons
    Looking forward to getting my setup for my Gen 1 with a subtle change to the rear SuperSpox. Sure Tim will post a pic up before shipping north of the border.
  6. _WOLFMAN_
    Contests won:
    Name:
    Dean Parsons
    Custom anodize carrier available from Supersprox. Thanks again Tim. Did full sprocket and chain setup through Pashnit.
  7. Skydyvyr
    Skydyvyr Registered
    Contests won:
    Name:
    This is a test. This is only a test. This is a test of the public...
    So it's time to replace the chain on my '05 Busa. It has 24,000 miles on the odometer and although the sprockets and chain look good, the chain is looser than I'd like and the axle is adjusted all the way back. I'm gonna tackle this myself, and it appears to be well within my technical capabilities. I'm most likely going to order the chain & sprockets as a kit from you (Pashnit) but I'm hoping you can help me decide between the three chain options you have on your site.
    What are the cost/benefit deifferences between these options:
    --GB530GXW-112
    --IRIS 530FB-116
    --RK GB530GXW-140
    Just as an FYI, my bike is stock length and I'll be going with 17/40 sprockets.
    Thanks for any assistance you can provide.
    --Andy
  8. 1busa
    1busa Registered
    Contests won:
    Recently ordered a Supersprox rear sprocket for my Gen1 and paired it with a new ZZZ chain :thumbsup:
  9. pashnit
    Contests won:
    Name:
    Tim
    It's spring and may be time to replace that chain & sprocket set on your Busa.
    How to know?
    Eyeball teeth on your rear sprocket. If they are bent, you'll see it. Put the bike up on the stand & rotate the tire while pressing the chain up and down. You're looking for tight spots.
    Tension should be the same all the way around as you rotate the chain a full revolution. If you've got tight-then-loose spots, your chain is toast & should be replaced.
    http://www.pashnit.com/product/supersprox/suzuki/hayabusa.html
  10. Dinothegreat
    Dinothegreat Registered
    Contests won:
    Name:
    James
    The shopping cart on the website isn't working correctly.
  11. MoNoXiDe
    MoNoXiDe Registered
    Contests won:
    Name:
    Josh
    I have the same setup. Really nice quality.
  12. Dinothegreat
    Contests won:
    Name:
    James
    These are still available?
  13. pashnit
    Contests won:
    Name:
    Tim
  14. Dinothegreat
    Contests won:
    Name:
    James
    Okay great! These look really nice. I placed an order but didn't get a confirm or anything, it's been a few days, just wanted to make sure it was coming! I see alot more stuff on the site I would like soon.
  15. pashnit
    Contests won:
    Name:
    Tim
    Another kit sent out to Justin. :thumbsup:
    On the way.
  16. Fritzjunker
    Fritzjunker Registered
    Contests won:
    Name:
    Bobby
    How much is a 45T rear sprocket for a carrozzeria 240 v-track wheel?
  17. pashnit
    Contests won:
    Name:
    Tim
    45T Black sprocket in stock for Carrozzeria , ready to order?
  18. Fritzjunker
    Contests won:
    Name:
    Bobby
    Was seeing about the price first. I am debating on a supersprox vs another vortex aluminum. Ive gotten bout 20k outta my current vortex aluminum sprocket.
  19. pashnit
    Contests won:
    Name:
    Tim
    Fritz - pm sent
Share This Page
