starting trouble
Discussion in 'Busa problems' started by manindsin, Jul 6, 2012.
  1. manindsin
    manindsin Registered
    Contests won:
    The bike was cranking but would not start. then suddenly it went dead. no indication/light in ignition etc on instrument panel. I have started opening the Left fairing to reach the fuse box. It is a year 2005 bike. Any suggestions please....
  2. bikerboy2182
    bikerboy2182 Registered
    Contests won:
    Name:
    Jeff
    first and always check the battery to see if it has charge.
  3. Busaboomer
    Busaboomer Registered
    Contests won:
    Name:
    Adam
    Check the battery first, if battery is below a certain voltage think its like 10 volts, the motor will slowly spin over but not fire off due to not enough voltage to fire off ECU, injectors, light the dash, and so on. If the battery is low how old is it? Have rectifier checked and stator checked to ensure proper charging system functions.
  4. kromdom
    kromdom wannabe HOON Donating Member Registered
    Contests won:
    Name:
    Romeo Insigne
    +1 million........lost count how many posters here with starting issues werre caused by a bad battery. Take your batterry to an auto parts store and have it LOAD-TESTED. BTW, welcome to the ORG (although you did sign up back in 2010).
  5. dadofthree
    dadofthree Seasoned Beef Donating Member Registered
    Contests won:
    Name:
    Robert
    Fuel / Fire / Air , start with a good load test of battery. Fully charge battery.
Share This Page
