OB_sebastien
SoreHead,
I have the EXACT SAME PROBLEM happening all the time. You push down on the lever and it just won't downshift unless you let the clutch out a bit. The lever actually moves down but doesn't have any effect. Usually happens when coming to a complete stop and don't have time to blip and downshift while still rolling or if I feel lazy and just pull the clutch in and stop in a high gear. Then when you try to downshift while stopped, it does it for sure. Also, sometimes I cannot shift from neutral to 1st after coming to a complete stop unless I let the clutch out a bit and then pull it in again and then I can get it in 1st. Ever have that happen to you also?
