secondary fan system
Discussion in 'Engine and Performance mods' started by jch364, Sep 7, 2009.
  1. jch364
    jch364 Registered
    Contests won:
    Name:
    jeff
    I was wondering if anyone is still selling the second fan set up? Buddy of mine bought one off the org last year and he said it fit perfect. I was thinking of doing this as a winter mod so i was trying to find out if anyone still does this and if so, how much?
  2. ham4864
    ham4864 Registered
    Contests won:
    Name:
    Ham
    well i just won a fan on ebay for .99 i'm going to make my own and save 140.00
  3. kjcili
    kjcili Donating Member Registered
    Contests won:
    Name:
    Kevin
    Why would you want a 2nd fan?
  4. jch364
    jch364 Registered
    Contests won:
    Name:
    jeff
    well i was thinking of using it with a manual switch. was thinking it would help keep it cool at the drag strip. tends to get hot of course so i thought this would help keep it cooler. was gonna get a muzzy fan blade also.
  5. djsin
    djsin Lily's Daddy Registered
    Contests won:
    Name:
    Todd Shingledecker
    let it cool down between passes..no hot laps and youll be fine
  6. Commuta_Busa
    Commuta_Busa Donating Member Registered
    Contests won:
    Name:
    Ken Klein
    stick with the OE fan blades they're more effecient.
  7. warezdog
    warezdog Registered
    Contests won:
    Name:
    jeff
    Did my second fan kit as well as the temp relocate mod, couldn't be happier when stuck in the horrid DC traffic. Save the 40 bucks on the Muzzy if you're gonna get a second fan. RCC sells a fan thats really easy to mount as well and you can tie it into your existing loom, just add a 15A fuse and no switch needed.
  8. kjcili
    Contests won:
    Name:
    Kevin
    2nd fan def not needed on our bikes. the reason they start to get hot is cuz after the fan has ran a couple times, the plastic blades absorb heat and become flimsy and move less air. Simply doing the Muzzy fan is enough to keep 'em cool. Engine ice would be an added bonus.
  9. kjcili
    Contests won:
    Name:
    Kevin
    The other problem with second fan is additional amperage draw.
  10. GIXERHP
    GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered
    Contests won:
    Name:
    JOHN HAYES
Share This Page
