Rcc electric water pumps
Discussion in 'Turbo' started by POWERHOUSE, Feb 1, 2011.
  1. POWERHOUSE
    POWERHOUSE Frank Site Sponsor Registered
    Contests won:
    Name:
    Frank
    As some of you may know, the RCC electric water pump that bolts on in the stock location has been discontinued. For anyone interested, POWERHOUSE has one left in stock. After this is sold, this style pump will no longer be available. There are, however, a few alternatives, again, from RCC: two universal style pumps, one with "push on" type fittings, the other with AN (-10) fittings.
    In addition, the bolt on "cylinder type" is still being manufactured. The universal types are the same price, $375, and the bolt on type will be selling for $475, available from POWERHOUSE.
  2. Fastfrog007
    Fastfrog007 Donating Member Registered
    Contests won:
    Name:
    Tim
    Why are they being discontinued?
    Bump...
    Sent from Droid using Tapatalk
  3. POWERHOUSE
    Contests won:
    Name:
    Frank
    Again, only the electric water pump that was meant to be installed in place of the stock water pump is being discontinued - the ones pictures above are still available. The reason the "stock style" electric pump is being discontinued has to do with the rising costs to manufacture it . . .:banghead:
  4. uaeproz
    uaeproz Registered
    Contests won:
    Hi Frank,
    Do you still have one in stock?
    Thanks,
    Abdulla
  5. POWERHOUSE
    Contests won:
    Name:
    Frank
    Adulla, I still have these in stock, along with the block off plate you would need to block off the hole when you remove the stock water pump. Do you want an electric pump with 10-AN threads (you put in your own fittings), or would you like the "push on" type? (you just push your hoses on and use clamps).
  6. uaeproz
    uaeproz Registered
    Contests won:
    Push type please with the block off plates.
    I'm ready to pay now.
  7. GNBRETT
    GNBRETT Registered
    Contests won:
    its a great item. Got one from Powerhouse myself.
  8. Jake whitebird
    Jake whitebird Registered
    Contests won:
    Is this a necessary item once a gen ii busa is aspirated?
  9. POWERHOUSE
    Contests won:
    Name:
    Frank
    An electric pump is always running at full speed. The advantage is obvious, and when you factor in the realization that you are no longer driving a mechanical water pump, you are freeing up horsepower as well, since there is another load removed from the power train. Is this a necessary item? If you are trying to get the most out of your cooling system, this is one way. Extra fans, relocating the fan relay, running fan switches, gutting thermostats are some of the other mods that can be done to cool down the beast . . .
Share This Page
