what exactly do you do with the marble or flanged bolt?no you don't all you need is a flanged bolt or a marble
plug the hose going to the air boxwhat exactly do you do with the marble or flanged bolt?no you don't all you need is a flanged bolt or a marble
I would have never thought about just cutting the air supply off. I thought that would have damaged someting, but it does make since. Thanks for the inputplug the hose going to the air boxwhat exactly do you do with the marble or flanged bolt?no you don't all you need is a flanged bolt or a marble
This will answer your questionWhat is the pair valve and where is it.
