On a 1st gen oil sight gauge there is a flat section along the upper housing. Should this be horizontal? Not just close but exactly parallel to the ground. Just discovered on the mid engine install is that to level this sight gauge flat section the rear must be raised 6 inches. With car level and at the full mark the level drops to just below low with the car raised and the gauge level. the attached pic is the show the flat section only. The pic from handheld and is not likely level.
Just wondering if the engine is mounted 5-10 degrees high in the front
Pls view your gauges and comment
