Oil change & spark plugs done in 50 mins.
Ok I guess I will be the big sap, I was messing with the Busa this weekend and I tried taking off both sides of the front fairings to see how they worked, I got everything off except the very front part of both sides, I had all the pins out and it would not come loose, I read and read the oil change sticky but just could not get it, way harder then the gen 1's
Got a tank bra comming this week sometime and I figure I will have to take off both sides again hopefully with better results, is there a trick to getting the front fairings off?
Like I said I had whole back off just not the front by the nose/headlight area
You need to push it up then pull it down as it has a little bevell that locks it into place :thumbsup:
if i race..i get a can of parts... got picked on for years about that with the duc...so ... i take things a bit slower now
