Need Help Putting A Turbo Kit Together
billy11281
Hi all
im looking to turbo my Suzuki Bking and been shopping around and found bunch of new kits altho a bit pricey for my budget was wondering if anyone could help me put one together within my budget of 2500 dollars , looking forward to 230 to 240hp street thank you all
My bad. I was thinking about the one Shaft has for sale. It's for a gen 1. Not sure what it would take to make it work. I am sure that someonehere would be able to chime in.
Take this with a grain of salt: turbo bikes and budget do not go hand in hand. $2500 budget has chinese eBay junk written all over it. You either pay to do it right or pay twice as much to fix your poop after it melts. Good luck :beerchug:
The gen 1 will fit
the plenum spacing is 5mm out on a couple of the throttlebodys , but a little longer boots can acommodate that if your more concerned with the $ than perfect alignment
Up pipe and left fan may need adjustment to clear
Know a guy that did this very conversion a couple of yrs ago, says the BK is a hoot with turbo
thats a b king plenum cost 250 also headers seller claims its an cast stainless steel double the thickness of all headers available , the header has proven to flow a minimum of 50% more at 42% more efficiency than any other hayabusa turbo headers they could find a 1000 bucks and Guaranteed to never crack . it has the standard t3 flange and is tapped for 3/8" bolts , i need help with choosing the right turbo , tial gate , oil feed and return lines and fitting fuel lines and air filter etc thank you all
