Modified Oil System
marcair
1550cc 2003 in daily driver. After rebuild last Summer needed to lower oil temperature. Welded AN8 fittings to pan. Oil pulled thru ftg on right side next to temperature sensor thru 180f switch to tilton 60psi max 1.7gpm max pump to front bumper mounted 11 x 5 x 2 cooler with 2 5" fans back to pan fwd of drain plug. Cruising around town is 170-185f. At 80mph @6k rpm for 1 hour is 200f max. Also remote oil filter. Comments welcome.
Exhaust system prohibits any oil pan external change.
