Kickstand at trackday?? Need Advice
Discussion in 'Racing Technical' started by motochris, Sep 19, 2011.
  1. motochris
    motochris The artist formerly known as Chris75181 Registered
    Contests won:
    Name:
    Chris
    This last Sunday the track management looked at my busa after lunch...said one of the tower people heard me scraping the kickstand.. sure enough kickstand was shaved down a bit..he suggest I zip tie it...I showed him it was Not loose.
    He said I should remove it..was worried I might high-side or something.
    This is a stock kickstand and the bike has not been lowered.
    Looking to see if anyone has had this problem at the track and what u did to fix it.
    Also if I remove KS for track days what do I do with the kill switch (leave it an wire it?) Or how do I remove.
    Any advice would be greatly appreciated.
  2. GSXcite
    GSXcite Squirrel Master Donating Member Registered
    Contests won:
    I pull mine off and use the Baxley chock. Jump the switch to complete the circuit.
  3. twotonevert
    twotonevert Member of P.E.A. Moderator Donating Member Registered
    Contests won:
    Name:
    James Wilson
    I would just zip tie it and use a chock. But how low are you getting bro, I can remember scrapping plastic and not dragging the kick stand. :bowdown:
  4. skydivr
    skydivr Jumps from perfectly good Airplanes Donating Member
    Contests won:
    Gen 1 or 2? I'd like to see the pic of you leaned over so far you scuff your stand on a gen 2, cause your plastics would hit long before...
  5. BusaWhipped
    BusaWhipped Donating Member Registered
    Contests won:
    Name:
    Dennis Heidler
    I've never removed or scraped my stand.
  6. motochris
    Contests won:
    Name:
    Chris
    ok...well I can remove KS when I goto track...not a problem..want to be safe.
    Last time I went to this track a "controlled rider", whom I was following and would follow me reomended I take off the feelers on my stock pegs. so this time around I did that. Now the kickstand...this is a 05 Gen I
  7. motochris
    Contests won:
    Name:
    Chris
    Anyone else have this problem.....?
  8. skydivr
    Contests won:
    Ok, I see your feelers scraped off (Which does happen); I sure would like to see a pic of your lean angle....
  9. 1ibandit
    1ibandit Registered
    Contests won:
    I would like to send $1 to the motochris needs a camera that focuses fund. Where do I send it.. I too would like to see the lean angle when u are hitting the KS.... Oh... In focus please.... ;)
    1ibandit
    88 ZL1000, 07 KaBusa
    Sent from my iPad using Tapatalk
  10. GsxrBots
    GsxrBots Motorboatin' Moonpies, Gangnam Style Registered
    Contests won:
    Name:
    Steve
    Chain looks good though! :rofl:
  11. motochris
    Contests won:
    Name:
    Chris
    I took feelers off...the one on this side is a bit longer(last pic) and I am wondering if it longer because of KS....the best pics I have are in the latest thread of ECR track day 9-18....
  12. twotonevert
    Contests won:
    Name:
    James Wilson
    Please dont take this wrong way, I know you ride well, but may I suggest you move your butt off the seat a little more thus reducing the lean angle? That sounds like you are really really low. If you start scrapping hard parts you are bound to low side at some point. I just hate to see you do that.
  13. motochris
    Contests won:
    Name:
    Chris
    Sorry guys probably was holding camera to CLOSE it was focusing beyond the KS.
    ..going track again on the 9th...maybe charles can give me some pointers, he seems experienced. I have video on gopro but not of me..... :-/
  14. motochris
    Contests won:
    Name:
    Chris
    Welcome any constructive criticism thanks James that's what a few riders around me told me (after I was warned about kickstand) so I focused the rest of the day on getting off the seat and shifting my head to the outside of the windscreen...this really helped cuz when my head moved my body followed....need to work on it plenty more...this only my second track day....thanks again
  15. Black Sheep
    Black Sheep They call me Baaah! Donating Member Registered
    Contests won:
    Name:
    Jonathan
    Before i started to move off the seat i scraped kickstand a couple times. Never took the busa on the track though.
  16. Twobrothersbusa
    Twobrothersbusa Team Gixxer Racing; IDMBT #1 Donating Member Registered
    Contests won:
    Name:
    Charlie
    That is the problem with video cameras....you can't be a rock star unless your buddy has one.
  17. Twobrothersbusa
    Contests won:
    Name:
    Charlie
    I started tracking on my Gen 2 and would scrub the feelers every now and then when I started. My experience that first season got me off the bike and the knees are what should be used as your guide. Are you dragging pucks and hard parts at the same time? Hard parts on asphalt = bad times.
    Is this you?
  18. Hayabusa4life
    Hayabusa4life I said Good Day! Registered
    Contests won:
    Name:
    Wilson H.
    Right before you take a pic, place your hand in front of the camera for a few seconds, that will help your auto focus to kick in.:thumbsup:
  19. Powers739
    Powers739 Donating Member Registered
    Contests won:
    Name:
    Ted
    Raise the rear 1"!
    I agree with the other post, just you butt off the seat as well as your torso. I also never had an issue at the track, but the rear was raised!
  20. motochris
    Contests won:
    Name:
    Chris
    Yep thats me.
Share This Page
