I bought a very lightly used 2009 Hayabusa several years back. This bike was basically brand new, barely ridden anyway, as I bought it in 2019 with 250 miles. Not being much better than the first owner, in the past several years I only put 100 miles on it as I have too much stuff and not enough time for it all. I do have a bit of an additional excuse in that it seemed to develop a problem a the next season after I bought it, so until now I'd just walked away from it.
Anyway after that first season of sitting directly after purchase, the clutch stopped working (it would not disengage). I did all of the common checks and it was not the lack of function of the master/slave cylinders or bleeding or blah blah blah. Went through diagnosing all of it anyway and still nothing, but then realized I could see the movement of the clutch basket by removing the oil cap. At this point it was confirmed that the clutch steels/fibers must've become adjoined or fused together somehow. I tried all I could to get them to break free, even try riding it around with the clutch zip tied, WOT pulls/wheelies you name it and this clutch was not going to break free for anything. Someday I guess I'd pull it apart and look at it.
So I gave up on it until the last year and went to mess with it again and then to add further salt into the wounds it would not even try to start. Admittedly I did put the starter through some hell in the process above as each time I'd crank it in gear with the prior problem the bike would be lunging forward as the clutch was locked, which no doubt put the starter through some trauma.
Today finally pulled it all apart. The clutch steels and fibers were absolutely 100% fused to one another, most every one of them actually having to be pried apart. So I ordered a new OE clutch kit to just end the saga there. Everything looked pretty clean aside for the steels/fibers, so that was a relief.
Now onto the lack of Starter function. I tested the relay, which was clicking, and all was well. 12v was making it to the starter, just doing nothing for the starter. This was confirmed when removed and bench tested as well. The new OEM starters are about $400 new so I figured I'd see what I could do with hopefully servicing it. So I took it all apart which was rather simple, lightly bead blasted the insides of the mid case and rear brush plate. Cleaned up all parts with solvent and compressed air, everything looked pretty much new. Even took the rotor/windings and polished up the copper contact portion with a dremel very fine buffing wheel, which looked new as well when done. Put it back together, still didn't work. Took back apart again and realized the brushes actually were seized and not "springing" down back onto contact with the rotors conductor. So pushed them down and worked them back and forth again and they freed up and the spring action was working to the point where they were then making solid contact. Upon reassembly and testing the unit now works perfectly, seized brushes being the actual issue.
Keep in mind the bike was always stored indoors, but that still did not help much in this case apparently and lack of use simply caught up to me. Anyway just wanted to share in case anyone else comes across similar issues, which in this case I feel like are 2 pretty whacky ordeals in one, but both pretty easy fixes each way.
Rob
Rob
