lowkeyenergy
Hi guys... First post.
I was recently in a minor accident that led the bike to scrape its left side agains the ground, destroying the main wiring harness.
I replaced the harness with a used one bought on ebay. Everything connected ok. Bike runs perfectly, only problem is strange behavior from the turn signals and headlights...
The right turn signal (front + back) stays lit and does not blink, always.
The left turn signal is dark if the switch is off. If the switch is on, the left signal blinks rapidly.
The low beam does not light at all.
The hi beam, if lit, will also blink along with the left turn signal (rapidly) if the left turn signal switch is on.
I have one of those aftermarket tail light/turn signal combos with LED, which explains the rapid flashing, but not the crossover between hi beam and turn signal.
If i disconnect the front and back turn signals, and tail light, the instrument cluster nonetheless behaves the same strange way.
Please help. I have spent the last 2 weeks missing days from work so I could repair my beloved bike. Now with everything else fixed and the new fairings waiting to be installed, I can't figure out this mysterious problem.
- rocky
- rocky
