(Powers739 @ Feb. 15 2007,16:01) I used a heat gun (or a hair dryer). Just make sure you don't apply to much heat to bubble the paint but enough to soften the adhesive. There are several chemicals you can use to remove the sticky goo left behind, ie goo be gone. Just remember whatever you use to remove the stuff left behind will also remove and wax (protective coating)...
Sorry no pictures...
