arthur39
Just a question on fuel supply to a Stage one kit, 6lbs boost. I have a billet rail with 3/8 npt threaded inserts, the guy I purchased it from suggested using 8an line or the equivalent 1/2" line from the tank to a 6an or 3/8" return line from the fmu. Is this overkill, or playing it safe? I need to decide on either 3/8 or 1/2 inch barb fittings which will dictate fuel filter size and inlet size from the tank. I have a Walbro 255 pump with 10 x1 internal threads and am not sure of the correct thread to barb fitting size for this insert. Any feedback on this will be helpful as well. (maybe a metric barb)
Later down the road I might do a spacer and 8lbs of boost, that would be the most for my setup. Thank you
