Definitely want to check this. If it isn't down check to make sure the switch is activated when the stand is up. The plunger should be all the way in when stand is up.i'm sorry but i have to ask this question. is the kickstand still down when you put it in gear? cause suzuki bikes the engine will dye when the kick stand is down & you try to shift into gear at the same time.
