Electric scavenge pumps
Discussion in 'Products' started by POWERHOUSE, Dec 19, 2012.
Thread Status:
Not open for further replies.
  1. POWERHOUSE
    POWERHOUSE Frank Site Sponsor Registered
    Contests won:
    Name:
    Frank
    Now available, another great product for you turbo guys who smoke too much!
    Low 3 amps draw
    Brass gears
    In line fuse holder included
    Durable metal construction
    Can run dry for brief periods of time, self-priming up to 3 feet, brushes and pump rated at 1000 hours
    1 year limited warranty, 3 amp fuse must be installed
    Flow rate 2 gallons per minute
    Comes with 2 fittings that convert a metric thread to 3/8â€￾ NPT (but 3/8â€￾ NPT fittings will also screw into the pump body)
    Retail: $235.
  2. RYC1966
    RYC1966 Donating Member Registered
    Contests won:
    Name:
    RYAN
    where is a good spot to mount the pump?
  3. POWERHOUSE
    Contests won:
    Name:
    Frank
    This pump is universal, and will draw well over 3 ft, so you can mount it wherever you want. What I would suggest is that it be mounted lower than the turbo and as close as possible to it, which on a Busa would be behind the engine under the front of the swingarm . . . this picture shows the pump mounted in this area on a ZX14:
  4. GIXERHP
    GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered
    Contests won:
    Name:
    JOHN HAYES
    Cool, how much?
  5. POWERHOUSE
    Contests won:
    Name:
    Frank
    Retail on this item is $235 . . .:laugh:
  6. GIXERHP
    Contests won:
    Name:
    JOHN HAYES
    Very cool, i think the bike on the lift will be seeing one of these soon!
    I have tried jetting the feed line and still smokes a little.!
Thread Status:
Share This Page
