jpsmith1
Problem:
System shifts under no load properly but not under load. It had worked properly for a couple years.
Further investigation showed the engine is not killing even with it programmed to max kill time in ecueditor.
Gear position indicator is working properly.
No fault codes showing on dash.
Air pressure set at 140 PSI (confirmed with two gauges).
No air leaks.
Attempts to fix:
Have replaced harness, solenoid, air line, cylinder, air line and regulator. Nothing is leaking.
Reflashed many times.
No visible problems with harness or connections to bike harness.
What is best way to diagnose the lack of any kill time? Is there anything I should be able to see when I have laptop hooked to ECU to test the input? The motor does not stutter at all. Could the mode switch affect the kill circuit?
Thanks!
Bike:
2009 Hayabusa
Cycle-tek air shifter system (shifter, harness, regulator, CO2 bottle)
Pair valve removed but has resistors from Greg Smith and also turned off with ecueditor
Flashing interface from Boostbysmith installed.
No air leaks.
Attempts to fix:
Thanks!
Bike:
2009 Hayabusa
