Dry Shifting
Discussion in 'Busa problems' started by alexde3, Apr 21, 2004.
  1. alexde3
    alexde3 Registered
    Contests won:
    Name:
    alexdelossantos@mortgagemaps.com
    Me and my buddy are having a discussion. We are trying to find out if dry shifting on a motorcycle does any damage to the transmission. if there are any mechanics or have an idea please give me an answer. thanks
  2. Johnnycheese
    Johnnycheese Registered
    Contests won:
    Name:
    Johnny Cheese
    what's dry shifting? rock.gif ???
    If you mean shifting without a clutch under a load yes it will damage the tranny. you need to take the load off of it
  3. alexde3
    alexde3 Registered
    Contests won:
    Name:
    is it not the same mechanical principal as a car?
    <!--EDIT|alexde3
    Reason for Edit: None given...|1082573387 -->
  4. fstbusa
    fstbusa orange peel is caused by excessive speed Donating Member Registered
    Contests won:
    Name:
    Travis
    what does "dry shifting" mean anyway?
    dry has nothing to do with anything. The clutch is a wet clutch regardless of how you shift it. Whether you take the load off the tranny or not is a different story.
  5. Revlis
    Revlis Re-Recycled, Busa-Less... Donating Member Registered
    Contests won:
    Upshifting or downshifting clutchless is harmless if done right. As long as you properly unload the tranny and preload your shift lever your GTG. If you are allways crunching gears or getting a jerky ride then you are doing it wrong, stop doing it until you get the technique down... It can make for some pretty damned fast, smooth shifts...
Share This Page
